Loop in/out or junction box | on ElectriciansForums
Discuss Loop in/out or junction box in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
E
elektrisien
Hi ,
A quick question about wiring downlighters. I am wiring college rooms, it is on price, so its kind of a rush job. There are 3 downlighters all about a meter from each other in the ceiling. The way the contractor wants it done, is loop in, loop out, meaning 3 choc boxes and connector blocks. Another way a spark showed me on site that is much quicker. is just taking all 3 downlighters to one choc box with a connector block. Can it be done this way ? Is it up to standard or a bodge job ?
Hi ,
Rather than post here just get on with it then, I would have connected them all by now LOL
It is a rectangular small plastic box that you use to for connections. The connector block fit in it , all the connections in the block is in the box. It makes it safe and protects the connections. You close the lid with a little screw supplied. Maybe you know it by a different name ?
Wagobox ? The contractor is supplying the materials. I cannot make up my own specifications as I go along. He supplied us with choc boxes and that is what is to be used. 6 replies and not one answer the question in any sensible way. Have you boys been in the beers ? Shall I post again on Monday ?
Like junction box
I thought they were DIY bits of kit, we use wago boxes or Jbs usually, those things are horrible to use, I wouldn't use them myself, little 5 amp connector blocks inside and too many bits to screw in like cable clamps etc, yuk
I know they are time consuming and very fiddly to use. But that is the way they want it done,it is probably the cheapest method. That is why I want to use as few of them as possible. So, can I connect all the lights into one ? They all work from the same switch. Or is it loop in, loop out ?
Reply to Loop in/out or junction box in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Thank you, it is always good to hear another suggestion :)
The challenge that you have with this is that you've no confirmed start point. Because you have a lack of an EICR you don't actually know what...
