Loop in with junction boxes | on ElectriciansForums
Discuss Loop in with junction boxes in the UK Electrical Forum area at ElectriciansForums.net
G
Gra426
Hi,
Just a quick question regarding lighting circuits. I believe some people are wiring loop in circuits with junction boxes in the void rather than terminating at the lamp fitting. Seems a pretty good idea with regards to less connections at the light fitting. However my understanding of the current regs is that all screwed terminations should be available for inspection which strictly speaking they would not be if in the void. Can anybody please clear this up for me?
Thanks in advance.
Gra.
Surely they would be accessible if the JB was under a floor board. Inaccessible would mean somewhere it can not be got at. It depends whether there is a way to get to the JB. Always always loops to lamp or switches for me. JB wiring is donkeys years old and very unpractical.
You could always use this.
[ElectriciansForums.net] Loop in with junction boxes
What about 2 way switching,...you cant loop the switches then from light fitting otherwise l-n-e to switch then back upto light but if using recessed/spots you need junction box again . So al in all
just leave junction box beside light fitting that uou can pull through
Always loop the lives at the switches and neutral's at the lights us, and we ALWAYS chop in at least 25mm boxes, even for 1G's. Makes it easier to terminate and when the customer shows up on the 2nd fix with a boat load of dimmers, they'll fit :)
Reply to Loop in with junction boxes in the UK Electrical Forum area at ElectriciansForums.net
How did it go?
