Loose fill insulation under floor | on ElectriciansForums
Discuss Loose fill insulation under floor in the UK Electrical Forum area at ElectriciansForums.net
ses
[ElectriciansForums.net] Loose fill insulation under floor
Came across this today in a property no idea if asbestos or not so told client put all floor back and tried to minimise disturbance as much as possible
Absolute nightmare trying to organise a asbestos inspection without waiting weeks
Property is 1890 build flats and this is only in two rooms insulating between flat below
Obviously not original insulation
Anyone got an idea of what it might be
Property not been touched since 1976 so pre this date
Its a purpose built block of apartments in West London
The flat is on the 5th floor and its between the 4th and 5th floor in living room and 1 bedroom
Its in every joist gap i could see so I do not think its from a cavity
I thought it could be for sound but no idea if they used asbestos for that or just as insulation
There does not seem to be that much help or information for when you do potentially come across asbestos
A helpline would be very useful
Reply to Loose fill insulation under floor in the UK Electrical Forum area at ElectriciansForums.net
