brucelee
Hi to all,
i am doing a 2391 course my exam is in june
I have a few questions if someone will please help
1).state two tests for a 230v circuit with a surge protective device which cant be disconnected
2). State why regular accurraccy checks, in addition to calibration should be carried out on a inspectors test instuments
3). explain the effects on earth fault protection of a circuit if the circuit breaker is installed in the neutral conductor only
4). state the external earth return path,exteral to the installation
5). If the armouring of an swa cable not used as a cpc does it need earthing or bonding
6). whats the scale and ranges/settings for test instruments
i.e. i). Low resistance ohmeter is it low ohms 0.02 to 2ohms
ii). Insulation resistance ohmmeter Mohms 0.00 to more than 200Mohms
iii). What is it for earth fault loop impedence tester for zs is it loop impedence range ohms 0.02 to 20ohms
for external loop impedence on a TN system
external earth fault loop impedence on a TT system
earth electrode resistance test
sorry there are lots but i have been checking GN3 and other books cant find all answers any help and advice much appreciated
