danielspencer
Hi there,
I have a customer that wants some lights fitted to an existing circuit.
When doing some preliminary testing on the insulation resistance for the circuit, I was getting strange readings. Line/Earth & Neutral/Earth were well over 500Mohms. When testing Line/Neutral, I was getting only 0.5Mohms. Line/Neutral connected together and tested to Earth are also well over 500Mohms.
Some of the lamps are really awkward to get to, and the customer would prefer it if I try not to remove them. I decided to carry out the test with all the local switches in the OFF position.
As far as I can make out all the light fittings are BC with no low energy or SELV fittings in sight.
I know I don't strictly have to carry out and record this test, but if anyone has any ideas why the Line/Neutral reading is so low, I would appreciate the input.
Many thanks
Many thanks
