R
rocker
What is low smoke zero halogen cable like to work with? I worked with some supplied white sheathed cable once which was a nightmare, really tough sheath and hard to run, and I think this may have been LS0H, does this sound about right? Just that I can get some of it for less than I can get standard twin at the moment.
if it's cheap, buy it and suffer the harder work
yep, nightmare to use and IMO pointless if you're running it in pvc containment anyway.
Hmmm yep sounds like the stuff I used. Total nightmare to work with.
It ain't THAT much cheaper, I think I'll give it a miss. Thanks all.
It's not that bad when you get used to it, I prefer pulling the LS0H to the normal grey T+E that stuff seems to burn to easy when pulling it through with other cables...
They both have there advantages though.
Low smoke cable
Electrical Tools and Products
rocker,
SEC-Tom,
