Low voltage cable | on ElectriciansForums
Discuss Low voltage cable in the UK Electrical Forum area at ElectriciansForums.net
T
Tom@tte
Hi guys
Does any one have any particulars on the best cable to use for low voltage lighting.
Got a large wiring scheme to do which is all low voltage LED lighting but want to make sure I use the best graded cable so not to cause problems later.
Been told to use a 2core twisted pair to gain a lower resistance to the drivers and a beldon twisted pair for the dimming but no one has stated a manufacturer or part number?
any one deal with this at all that can suggest a good graded cable
Cheers lads Tom
draka make a cheap belden equivilent. you want beldon 8760 (2 core belden)
3 core yy would be my choice for the power unless you want singles then I would use tri rated.
you will need some bootlace ferrules though because the strands are very fine
Reply to Low voltage cable in the UK Electrical Forum area at ElectriciansForums.net
One of those backlight Chinese testers may have helped that’s if the tester didn’t catch fire or electrocute you. LED TV Backlight Tester 12W LED...
2 3 4 5
4K
My bafflement increases. I swapped the offending light with one elsewhere on the back of the house - one of those that's on a circuit of its own...
