Low voltage tension wire lighting system | on ElectriciansForums
Discuss Low voltage tension wire lighting system in the UK Electrical Forum area at ElectriciansForums.net
polo1
Glasgow
Hi, anyone have any experince of these? I understand that a Type C breaker may be best? I've been asked to install a system of 5 x 50w on a 300va transformer witha run of approx 10m from the board to the transformer.
Any recommendations on make, size & type of breaker etc?
Regards
Thanks Tony. Believe it or not, I've had an email from the client - they want 10 of these....yes, 10 x 5, 50w units! It's a museum and they are apparently to be used for exhibit lighting.
Is there likely to be a problem in having more than one unit on a suitably sized circuit? ( I don't yet know what the switching arrangements are to be).
Regards
As Tony said, split up the circuits as much as possible to avoid nuisance tripping on start up.
We did a job similar to this for the National Trust a couple of years ago and had the same problem, so ran in some extra feeds and switched each transformer seperately.
Reply to Low voltage tension wire lighting system in the UK Electrical Forum area at ElectriciansForums.net
As above, check the whole cable run and look for damage or any junction boxes that might have trouble inside them. Water getting in is a common...
Hello Ric2013, MJPD29 and westward 10. I have a multimeter that I tested the voltage with and before I open the socket up I use a plug in tester...
