Hi! I'm willing to build up a network within my residential house which includes outdoor equipment for WAN access. And I'm failing to figure out the best way for me to make it work reliably, especially in terms of lightning (EMI) protection. So let me introduce all the necessary info regarding my setup:
1. We have like 100-200 houses neighborhood, all houses siding one near another, so you may surely say it's not a single house in the middle of the field.
2. Unfortunately I don't have any proper grounding within my house, i.e. there is no somewhat like centralized grounding bus or bar with all devices grounded to it.
3. I have an LTE router kit with PoE powering for outdoor use with a grounding terminal. The manual says I should definitely use it for proper grounding whatever it is. And manual also says that I should use a shielded CAT5E cable to connect the outdoor router to my local indoor network.
4. .. and also the manual suggests that I use a mast for mounting. Which I don't currently have, yet I'm willing to install some short L-shape mast on top of my house wall to get the router somewhat 0.5-1.5 meters above the house roof. It has NO direct connection to earth.
And now the fun part begins. Shielded cable, router itself and a mast should be properly grounded as per my understanding. For the purpose of lightning and other EMI noise protection (weather induced, I don't really expect any extensive industrial radio interference or like). Unfortunately I can't use any professional help because the industry itself is filled with amateurs with no proper knowledge in my specific country. So what should I do? The googling and self-educating part has leaded me to a probable solution:
a) the shielded cable should be grounded from a single side, the outdoor side, as my indoor equipment does not have any grounding at all anyways; also I have surely no idea on how to ground an indoor router with a plastic case and absent ground terminal; so for that reason I use an FTP RJ-45 connector on outdoor side and basic UTP RJ-45 connector on indoor side.
b) as per my router, I simply connect the grounding terminal to the mast with a somewhat 6AWG short solid wire
c) then I set up a local grounding with a specifically designed for burying metal rod and attach it to the house wall with a clamp (pretty much like NEC picture suggests? the one is attached)
d) finally I connect the mast and the rod via another clamp with a 1AWG grounding conductor
e) I definitely should use some discharge/surge protection unit, yet I'm not aware of how to do it correctly
The questions:
1. What flaws does my plan have? What should I fix in it?
2. Should I or should not worry about my grounded mast and antenna acting as lightning rod? Is having lightning rod like this is better than having none at all?
3. What about surge protection unit? Should I use it on a single end near the antenna or should I place it near my indoor equipment too? In latter case, should I ground it to my mast too?
Thank you for your time reading it.
The questions:
