Sherb
Just to let u know, I have just come across a jointbox that someone has made off in a Thundercats lunchbox !!!! Do you think it would be okay left with a bead of silicone around the lid, or do you think I should re-do it in an IP rated box ; )
Fantastic...... Any Pics!!!
Re Do with an appropriate IP rated box.... That's unless the thundercats box has an IP rating on it?!?!?
Had it been a "Bob The Builder" lunch box you would have been ok, i'm sure their rated & have BS/EN No. :ciappa:
That is an great idea!! Great accessibility lol just make sure you stick a 240v sticker on it and jobs a good one
When we moved into our house, the previous owner hand a small pond outside, which had a small pump in it, it was fed via a 3 core flex running along a wall, going to a small tuperware box which had a single socket outlet in it, which in turn was fed from an extension lead from an socket inside. To be fair to the guy he did drill a drain hole at the bottom of the box.
Found some connectors a while ago screwed to a joist under a floor with a coffee jar lid fixed over the top on a tt system with no stake and earth via water main was a right mess the whole job
Hi, I did a PIR on a static caravan recently which had 3 cables jointed under the van in an old tupperware box. But that was ok cos it was microwave proof.
Did he drill that hole when installing it though, or as a 'mod' after it filled up with water and took his rcd out?
I actually seen a tuperware type box in a pool pump room once the checky git had actually put cable glands in it. tbh it worked ! not conventional but i reclon as good if not better against water ingrese as some ip65 boxes ive seen. you can laugh but i seen it.
Lunchbox jointbox
Thread Tags
Sherb,
mogga,
