lutron | on ElectriciansForums
Discuss lutron in the UK Electrical Forum area at ElectriciansForums.net
Reply to lutron in the UK Electrical Forum area at ElectriciansForums.net
Well conventional wisdom says that you just parallel ('piggy back') as many switch sources as you need, all fed to the contactor coil. If for...
As above. Assumin you aren't working in the bathroom , then there is no restriction what a DIYer can do or can't do when repairing a circuit. But...
