lux sensor | on ElectriciansForums
Discuss lux sensor in the UK Electrical Forum area at ElectriciansForums.net
the pict
Mentor
Brodick
Anyone know of a dusk to dawn sensor with a time option and movement sensor, IE on at dusk off at say 1 AM off at dawn, on with movement after dusk
Yeah I know
Pict
Client wants three outside lights controlled, on permanant at dusk, off around 1 AM, on by movement after that off at dawn, rather than assemble from a timer, Lux sensor and a PIR I thought a off the shelf item if available
Pict
Reply to lux sensor in the UK Electrical Forum area at ElectriciansForums.net
That will work fine as long as the Pirs use relay switching, some don't.
That will only count when the alarm is active o/p said tamper. O/P doesn't seem to be in any rush to give more info, so I doubt anyone else will...
