Mage sunfixing mini flash alu for slate roofs | on ElectriciansForums
Discuss Mage sunfixing mini flash alu for slate roofs in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
J
J-low
Has anyone had any experience in installing the Mage mini flash alu fixing system. I'm looking for a quick solution to fixing a 50kw system to a fibre slate roof and it looks like it should work. Your thoughts and opinions are appreciated
Reply to Mage sunfixing mini flash alu for slate roofs in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
You need to pass the job on to someone who is competent and up to speed with solar installs and regulations .
I'm looking for advise on the type of mounting system suitable for these types of tiles. These are sort found on new build houses. They are...
