B
BluSparx
Hi All
Just wanting a bit of advice on how to route a main bonding cable.
The layout of the property is
Water Mains enters in the kitchen
Gas mains enters under the stairs in the hallway
CU installed in Kitchen cupboard
Elec Meter installed in a separate cupboard under stairs
My thoughts were to run the bonding as follows:
Attach to water mains in kitchen and run around the outside of the property and then bring back in where the gas mains enters the property attaching to the gas pipe and then to the Earth (TNC-S) system
My original thought was to take up through into the void between ceiling and upstairs floorboards, and bring back down at the where the gas pipes come for the boiler however the customer doesn't want me to do this as will result in tiles being removed in the kitchen.
Thanks in advance
Thanks in advance
