G
gesl
I have a CU change job and the water pipe supplying the house is lead. The lead enters the house then runs right under the house and into the kitchen where it is jointed to copper. The regs say bond where it enters the house (which is convieniently underneath the CU), but there appears to be some argument wether it is ok- and how- to bond to lead pipe.
What is right? and where is it in the regs?
Assuming you were using it for your competent persons inspection and had to explain your reasons, what would you do?
Cheers
GESL
Cheers
GESL
