Main Bonding Plastic Water Pipe | on ElectriciansForums
Discuss Main Bonding Plastic Water Pipe in the UK Electrical Forum area at ElectriciansForums.net
V
vespa
Hi I have noticed that the water pipe in my own house has mains bonding to the CCU. However the incoming pipe is actually plastic that has been painted white. I know the on-site regs say bonding in this circumstance is not necessary. It is however providing an earth passage..albeit into the building. As I intend to replace the CCU shortly would any kind person please advise if is better to remove completely or bonding or leave it where it is the continuity reads 0.07 ohms. Many Thanks
What is this CCU everyone seems to talk of lol.
Bonding plastic pipes achieves literally nothing. It's not needed, leave it in if you want but its pointless.
Flip a coin if you can't decide.
I went to a house which had been rewired and re plumbed in plastic. It had incoming water in plastic, a short length of copper with a stopcock which was bonded and then plastic throughout the rest of the house.
I have had this issue with a few new constructions in properties, the Incoming Pipe PVC and the Rest of the pipe work also PVC this also includes all heating in PVC, so the new good practice would be to bond all the Heaters with a Radiator clamp and back to good old Cross bonding everything, rofl...Isnt electrics fun..
I did the same, I bonded my bike as its always lent against the wall.
Enlighten me. How do you control a consumer?
[ElectriciansForums.net] Main Bonding Plastic Water Pipe
And what's so funny about calling a consumer unit its proper name of CCU?
Jesus,....Don't give newbie DI's the wrong idea, we'll be having a stream of them asking about bonding every heater in the house now!! :redface:
:thinking2:
yeah...i know about DB1...DB2 etc....
i just had it as main panel....incoming
distribution board....subs
but as you says....
I think I'm coming at ya from a different perspective. Put it this way, you'd never be able to go into a shop and buy a 'sub DB' haha!
I agree though with your names. I think my main point is that the terms 'CU', 'Consumer Unit', 'Fuse Box', 'CCU', 'CCCCCCU' or whatever these DIs call 'em don't really enter my vocabulary. It is a DB!!! end of! :D
its just i always refer to domestic boards as C/Us
I used to do so too in domestic when I first started for all but about two weeks but the problem is I got sick and tired of the following converstion happening:
ME: "Where abouts is your Consumer Unit?"
CUSTOMER: "My what???"
ME: "Sorry, your Distribution Board"
CUSTOMER: "Oh right, yes, it's under the stairs"
:D
Round here in deepest darkest zommerzet, we always calls them 'fuseboards' unless there really big then we calls them 'girt fuseboards' or alternatively 'panels'.
Consumer unit is a rubbish term invented for domestic installers, a fuseboard is a much more accurate term IMO
Thing is you can have a house that has all copper inside but have a plastic supply pipe. years ago because of metal cold water tanks and copper immersion tanks we had "Electrically and Mechanically Sound" connection but the introduction of plastic started to cause problems ie changing the zinc cold water tank with a plastic tank so needing a bit of cross bonding needed here and that ok then the introduction of plastic pipe and joints that terminate on to a copper pipe.
So its left to the poor spark to decide if it is required so for me my house had gas water bonded and cross bonding on the bathroom ,kitchen ,CH cupboard and at the plastic cold water tank. Transco has visited and replaced the main gas incomer to plastic and the water pipe is copper until it hits the main in the street to plastic and no doubt this could be replaced in plastic as well.
You can also at the time conclude that the pipework in the house is electrically and mechanically sound and then bond it only to find 6 months later the owner gets a dishwasher fitted and the plumber fits plastic T pieces in but is under no obligation to fit cross bonding.
One other thing that is starting to come to the fore with this is what I call a borrowed earth where because the gas or and water supply pipes are metal then houses that have their gas/water bonded the owner gets a visit from BG and find the technician saying do you know that you do not have and earth why well because BG guys are starting to test for an earth but utility companies are replacing metal supply pipes with plastic. Examples I found was that the customer had been told they did not have an earth so I asked if anything had changed the replay was not in the house but Tranco was in the area changing the pipes result being that the house never had an earth but because he had gas bonding as did the guy next door he was borrowing and earth
Reply to Main Bonding Plastic Water Pipe in the UK Electrical Forum area at ElectriciansForums.net
Ok. Thanks
C
Noisy main cold water pipe, my plumber hasn't heard this before. Hi Folks, Would like to cast the net far and wide to try and get some resolution...
ComfortablyNumb
C
You can splice at the first or second ground rod but you will need an extra tear drop or acorn for a 5/8 ground rod. You are allowed only on wire...
I think that you are correct due to the position of the cable. Thank you for taking the time to reply.
6K
