Hi folks,
Just wanted to check and see if bonding is required in this situation:
I'm erring on the side of not required, however if anyone could shed any light otherwise I'd be very grateful!
Tom
- There's no bond to water pipework, bond to gas all present and correct
- There is a piece of plastic pipe at the point where the water enters the building, probably around 100mm in length
- There is then a mix of copper and plastic water pipework throughout the installation
- I don't think there's any metal water pipework which penetrates the floor at any point after the service comes into the building
- There is no continuity between any of the copper water pipework and the MET (Megger reads >99.9kOhm)
Tom
