Main Bonding | on ElectriciansForums
Discuss Main Bonding in the Australia area at ElectriciansForums.net
SSE
Working at a house today that had a 10mm earth run to the main incoming water but then a seperate 10mm to the incoming oil. Just wondering if this should be just one continuous run going from cu-water-oil or is this acceptable?
Reply to Main Bonding in the Australia area at ElectriciansForums.net
Any metalwork connected to the MET could rise in voltage compared to true earth under an open supply neutral fault (on TN-C-S), and that would...
Many thanks all. Very helpful to be able to bounce these things around. Was fairly happy with it all initially, but once the seed of doubt is...
Recommended Sponsor News
Hi everyone,
