main earthing conductor | on ElectriciansForums
Discuss main earthing conductor in the UK Electrical Forum area at ElectriciansForums.net
M
michael_brooke
Hi all
I come across main earthing conductor coming out of fuse carrier which is 16mm earthing into henley block then 10mm out of henley block to main earth terminal in cu, ive been writing down 10mm as main earthing on test paper, would like to know what every1 else puts in this situation,.
Reply to main earthing conductor in the UK Electrical Forum area at ElectriciansForums.net
Obviously you need to check the means of earthing, Ze, and polarity no matter what for the EIC. As above, if anything looks dodgy then EICR is a...
