Main Earthing Terminal | Page 2 | on ElectriciansForums
Discuss Main Earthing Terminal in the UK Electrical Forum area at ElectriciansForums.net
M
marshr02
Hi folks. TN-S System with MET near incoming as you would expect. The 10mm2 bonding conductor (gas) passes through the CU to reach the MET due to the physical layout. Is there any reason why it can't be terminated inside the CU alongside the 16mm2 earthing conductor. Obviously testing of earth might be slightly harder. I suspect it may still be worth carrying it to the MET. Cheers
There's no reason why you can't but imo mets are best external especially on larger installs where you have gas, water, sprinkler, steam, oil and structural to contend with. I label up all mine as well just to be extra neat and clever.:rolleyes2:
- - - Updated - - -
Wow - posted my question - then went for some tea - come back, and tons of replies - none seem for me - apart maybe from this one?
thats caus its a bit well...hmm...
Would the said 'larger' install not be 3 phase though where you would be installing a D/B instead of a 'tiny' C/Unit then your MET would be a big twXX off earth bar inside the D/B instead of external?
Just wondering:speechless: not disagreeing !
Reply to Main Earthing Terminal in the UK Electrical Forum area at ElectriciansForums.net
Indeed it would be. But that would mean having 2 things to disconnect instead of one. More margin for error. Of course, any diligent spark would...
loz2754
L
Check the clearance between the back panel and/or terminal cover that you've removed. Look for small burn marks.
