main equipotential bonding | on ElectriciansForums
Discuss main equipotential bonding in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
1983
Hi all some advice please.
when it comes to main equipotential bonding can i run a 10mm2 from the met to the incoming water pipes and a sperate 10mm to the gas or does it have to be a single 10mm from met to gas and looped on to water pips? and also if the main equipotential bonding is in place do u still need to cross bond the central heating pips?
Has to be a single uncut run from CDU to water then an uncut loop to gas oil etc , or you have to run 2 seperate 10 mm from the CDU
Reply to main equipotential bonding in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Was there any toast to go with the beans? Just joking I think that you ment beams and not beans I am dyslexic and simple mistakes tend to jump out...
Any metalwork connected to the MET could rise in voltage compared to true earth under an open supply neutral fault (on TN-C-S), and that would...
