- Joined
- Mar 21, 2011
- Messages
- 3
- Reaction score
- 0
Recently doing a periodic inspection, i came across a 10mm bonding conductor to a external building (valet bay) waterpipe. However the the main bonding conductor on the the water into the main bulding is 35mm (95mm Neutral), the water in the external building is fed by a plastic pipe underground from the main water supply. I am wondering if this is a fault and if so what code it should be? many thanks
