main fuse blown | on ElectriciansForums
Discuss main fuse blown in the UK Electrical Forum area at ElectriciansForums.net
growler
Basingstoke
was called out to house earlier where couple had returned from holiday to find they had no power. on closer inspection I discovered that the main 80amp fuse had blown, no mcbs or rcds had tripped. any ideas ?
I've had a couple of service head fuses blow, very random times as well as there was no reason for them to do so.
I agree with Murdoch, sometimes they just pop.... Get the fuse changed and job done!
Customer of mine had the main fuse blow due to a fault on a junction box this was followed by a smell of burning plastic didn't blow the consumer unit fuse
There could be a fault that has blown clear under fault conditions and taken the main fuse
The old wylex push button breakers can be another one , when anyone trys to reset with a fault in place ,quite often takes out the main fuse ...
At very high fault levels and a fault close to the consumer unit the main fuse could clear the fault because it takes a finite time for the contacts to move in the magnetic trip.
Reply to main fuse blown in the UK Electrical Forum area at ElectriciansForums.net
My thoughts exactly! Snowed under with work at the moment, so might have to pass it on 😬😬
