Main fuse help. | on ElectriciansForums
Discuss Main fuse help. in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
schoe
on my installation the consumer unit is protected by a BS 88 fuse 100a, i was just looking in the on site guide and it says the rated short circuit capacity is 50 at 415 v.. when doing my PSC i got 1.6 ka and PEFC of 1.4ka does this mean my main fuse is to low to deal with possible prospective fault current?
Thanks as always Chris
Reply to Main fuse help. in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Just stick the 63amp fused connector before the Henley block , or Lucy block as you call it, and your all good, as for your 2nd point, , the...
