Main Fuse ID Help | on ElectriciansForums
Discuss Main Fuse ID Help in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
stujham
Having trouble identifying the main fuse on a recent CU change ( 1939 Semi ) to put on EIC, it’s an Aeroflex Fluvent Type AFS 60A rated, dimensions are approx 78mm long by 17mm wide.
Have tried DNO and are no help.
Any help would be appreciated as I am unsure of the KA rating.
I have recently found an old fuse of this type which was bypassed with a bit of wire. The fuse itself was destroyed apart from the metal caps.
Does anyone know where I can find a replacement for this type of fuse? The carrier is thinner than normal domestic 1361 II so it won't fit and a new carrier won't fit into the old cut out.
I can't find anything like it online.
try the fuse company.
Reply to Main Fuse ID Help in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
