schoe
Hi all I'm just filling in my test paper work but I can't fill in the section charteristics of primary supply overcurrent protective device because the main fuse is sealed and all it says on the outer casing is 100amp. Does anyone have the contact num for the electricity board so I can clarify the fuse rating, type and bsen finish my paper work,
Thanks chris
Thanks chris
