Main Isolators | on ElectriciansForums
Discuss Main Isolators in the Australia area at ElectriciansForums.net
P
pencilpusher
My "main switch" is an isolator fitted in the meter cupboard by the DNO. The installation is 10 years old. This appears to be single pole. Maybe it does isolate both poles but it is very small. Is this right?
Thanks PP
Photo attached. The switch is in the middle of the isolator so I suspect it's DP. Maybe a silly question but I am still learning and want to know everything!! Thanks. PP
[ElectriciansForums.net] Main Isolators
double pole. can clearly see L and N on the pic.
I could see that but was not sure what the switch, switched. Thanks all. PP
EDIT: As usual, there is no BSEN number shown at all on the sides etc etc. What do you think the BSEN should be for an isolator which I believe is different from a CU main switch?
Reply to Main Isolators in the Australia area at ElectriciansForums.net
I might have got lost here, but the rotary iso is rated at 63A so 25mm armoured still wouldn't make the install satisfactory. Assuming everything...
For a TN system neutral is deemed at earth potential.
