Main Protective Bonding conductor around an external wall. | on ElectriciansForums
Discuss Main Protective Bonding conductor around an external wall. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
M
murf20
Is it OK to run a Main Protective Bonding conductor around an external wall in black conduit?
Secondly are there any suggestions as to what you can sleeve this through a cavity wall other than 15mm conduit, - anything smaller.
or get a length of 10mm plastic water pipe from the plumbers merchants. you can buy it in 3m lengths from plumb center. it's ideal for 10mm bonding cable.
Thanks for the advice guys. I assume it should be protected in conduit around the outside wall but under a porch area it can just be clipped direct to the wall.
Reply to Main Protective Bonding conductor around an external wall. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
np I still have that spool to eventually get round to running a line outside Main challenge is doing it neatly haha
An example of the long term race to the bottom of quality of work in our industry, IMHO.
