Main Protective Bonding Conductor question | on ElectriciansForums
Discuss Main Protective Bonding Conductor question in the UK Electrical Forum area at ElectriciansForums.net
Somewhere
Hi guys
Would appreciate your comments on the following.. I am currently involved in the refurbishment of a building with 2 service heads (both in use) but only one gas intake and one water intake. What are the main bonding requirements in this situation? I am assuming both MET's require a bonding cable to the gas and water intakes? Many thanks in advance.
Hi guys
Without eyes on this install, it's difficult to assess, use the MET related to the service head you are relying on???? Anyone??
1 to the gas, 1 to the water?
Seriously though, why is there 2 electrical services if its only one property? Speak to the supplier and see if it can be combined to just one.
Separate supplies to separate buildings? How does the installation itself have the electrics separated?
If one electrical supply serves the building with water, and the other doesn't... then take the bond from there.
Reply to Main Protective Bonding Conductor question in the UK Electrical Forum area at ElectriciansForums.net
I might have got lost here, but the rotary iso is rated at 63A so 25mm armoured still wouldn't make the install satisfactory. Assuming everything...
  • Solved
There is an article about that here: https://www.cement.org/learn/concrete-technology/durability/corrosion-of-embedded-materials It states...
