Main switch and breaker arrangements which way..... | on ElectriciansForums
Discuss Main switch and breaker arrangements which way..... in the UK Electrical Forum area at ElectriciansForums.net
Lounge
Do you prefer to do them I prefer Main on left breakers to the right 6A > Highest reason for asking ? I have seen a few pics on here of late with main on right.
ATB J
I usually reconfigure to suit the installation, and like Lenny said High to low (as this was the way I was taught) from the MS/RCD.
Sometimes on CU replacements this is not always easily possible, but I try to keep to this convention where possible, I suppose since almost all CU's nowadays have 100A busbars this is not as important as it once was.
Reply to Main switch and breaker arrangements which way..... in the UK Electrical Forum area at ElectriciansForums.net
Ah yes my apologies, thank you much appreciated.
I've seen a few posts here which tend to suggest that wiring in a motorhome (or caravan) wouldn't be subject to normal inspection rules, but even...
