Main switch AND isolartor in consumer unit | on ElectriciansForums
Discuss Main switch AND isolartor in consumer unit in the UK Electrical Forum area at ElectriciansForums.net
G
gvelec
Hi all, any ideas as to why this installation has an isolator next to the main switch? To my inexperienced eyes, this seems unecessary waste of real estate.
Sorry. User stupidity! Domestic board. Hope it works this time. I can preview it fine!
[ElectriciansForums.net] Main switch AND isolartor in consumer unit
Here's a close up. I need to free up space on this Wylex at some point for a couple of new circuits, so am doing 'preliminary enquiries' :icon10:
  • [ElectriciansForums.net] Main switch AND isolartor in consumer unit
I too think that it was once a dual RCD board and either due to a faulty RCD or a fault that couldn't be found the "spark" has replace it with a main switch. I would test the circuits then fit an RCD back into the board
Seems to be the case which explains my other problem on my other thread where I'm having an earth fault. If there was an RCD in place on the board, the sockets in my kitchen (next to isolator on board) would keep on tripping.
Reply to Main switch AND isolartor in consumer unit in the UK Electrical Forum area at ElectriciansForums.net
However it's done, you need to have a guarantee of no sharp/unprotected edges that can damage the insulation. Personally, I'm not that impressed...
Yes, I was referring to simple installations such as domestic as that is what the thread is about. I also said should rather than must because I...
davesparks
