Main switch fuse | on ElectriciansForums
Discuss Main switch fuse in the UK Electrical Forum area at ElectriciansForums.net
the pict
Mentor
Brodick
Where can I get a 1361 40 A that is the same physical size as the 100 A.
Pict
Reply to Main switch fuse in the UK Electrical Forum area at ElectriciansForums.net
Obviously you need to check the means of earthing, Ze, and polarity no matter what for the EIC. As above, if anything looks dodgy then EICR is a...
K
Ah, I see. The op question is ambiguous, and I took it that he wanted to add a socket for a washing machine from and exiting switch fused spur. A...
