A
ambrad
Hi all
Could i have some advice regarding what to put in to the main switch or circuit breaker part of an niceic domestic EIC.
I have just started testing and inspecting so sometimes need a bit of guidance.
The problem i have got is the 2 way Hager cu provided. The cu is from split 25mm tails and the rcd is being used as the switch. There is also 2 mini circuit breakers for the circuits.
the problem i have is that the only information on the switch/rcd is CDC 240W, 40A, 30mA. On the test cert it is asking for a Type BS(En).
Do i just put the information in i have got or is there a table or guide that will tell me what this rcd is in more detail.
Hope you can help
Hope you can help
