Main switch | on ElectriciansForums
Discuss Main switch in the Australia area at ElectriciansForums.net
sparks1234
Hertford
Interested in your opinion, I have always been under the impression that an installation should have a main switch, one switch turns everything off, years ago you just tapped off the Henly block, what do other people do if the original consumer unit is full?
Yeah, i'd prefer that, although its pretty hard to install an isolator between main incoming and henley blocks, without removing the main fuse's...(I'll never remove fuses, too risky for me.)
What i tend to do, is after the henley blocks fit a fused isolator that then feeds each fuse board. (keep all isolators in one spot, and make sure adequatly labelled) It also provides isolation to only part of the system, without shutting the whole place down..:)
Good idea, but that doesnt provide one point of isolation for the whole install.
It doesn't provide one point of isolation, but if their labelled up clearly and placed in the same location, why not isolate them all, if needs be?.. A qualified electrician should be know to prove test prove then lock off..
Btw how was that testing sheet i sent you?:)
Reply to Main switch in the Australia area at ElectriciansForums.net
I replaced a CU a few months ago along with isolator. Along comes Mr Eon meter man to fit a smart meter told the customer that he has to replace...
Obviously you need to check the means of earthing, Ze, and polarity no matter what for the EIC. As above, if anything looks dodgy then EICR is a...
