Hi guys, sorry if this has been asked before.
I’m currently in a flat where the tenant queried the water bonding. There’s a 6mm green and yellow leaving the DB and goes to the gas meter as it’s clipped direct I can see it isn’t continuos and go to the water. There is also no other bonding conductors leaving the DB. When I carry out a wander lead test I get 0.03 ohms across the Gas bond which leads me to think there is a link somewhere to the water that isn’t visible or it’s just the reading going through the boiler. When I go onto the 16mm when it’s disconnected from the DB I get 0.00 ohms. There is also a plastic bend straight after the incoming stop cock and the copper work after that is getting a resistance of 15.1k ohms. My question is should water pipes after plastic bends and joints therefore be bonded ? And as I’m getting a good reading on the wander lead even though there is no visible cable at the MET is the bonding ok ?
Apologies for the long winded question. TIA
