mains kitchen lighting | on ElectriciansForums
Discuss mains kitchen lighting in the UK Electrical Forum area at ElectriciansForums.net
Uk
Hello
After some advice, what is the easiest way to achieve the following...
Domestic kitchen
Got some under cabinet lighting which is controlled by the light switch
Ive also got some decking lights which are plugged into mains
What is the best and easiest way to merge the two so they are both controlled by the same lighting switch?
Simplest solution is to use two or more Wireless remote control switches on different electric circuit/devices, to be controlled by one in your like, not expensive indeed.
Agreed. Trying to tie them together with wiring will be messy and disruptive.
Go for wireless. Some have wireless, physical switches, and/or they can be controlled separately or together by using that fancy new fangled APP/Alexa/IFTTT/etc thingies.
PS. Not at all TL.
Reply to mains kitchen lighting in the UK Electrical Forum area at ElectriciansForums.net
Thanks again for your help, now solved đź‘Ť
Joining the ends of the radials together to form a ring, and changing the circuit protection to a single 32A would solve the MCB overload problem...
