Mains Smoke Alarms | on ElectriciansForums
Discuss Mains Smoke Alarms in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
B
bigbaddave
Just had a call from a customer who has reported that there interconnected smokes are going off early in the morning, All at once.
Now then, The say they have changed the batteries tried hoovering them but still no joy.
There is clearly a fault with one on the on the circuit but as for testing is it just trial and error or is there any means of testing?
The only factor I can think of when they are going off is the cold. Would this make a difference and why?
Its a new build ish. Id say 4-5 years old. not sure if the smokes are the original i would presume they are. Ill take a look when I go to the job.
if they the type linked by a three core wire then go and disconnect the signal wire, leaving them not linked together. leave it till the faulty one will give alarm.
They don't like the intense cold , Check for operating temperatures for the make and compare to temps in unheated areas - halls, stairwells etc.
Reply to Mains Smoke Alarms in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
This is it though…. To put one following the letter of the law, so to speak… would be a smoke in the hallway outside the bedroom door… then a heat...
Personally I won't do fixed price work unless there is a clear spec for the job including things like smokes, data, TV whatever else the customer...
