Mains tails EICR coding | on ElectriciansForums
Discuss Mains tails EICR coding in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Scotland
Hello everyone, I'm wondering if someone could help me with some EICR coding. I am aware that bringing mains tails into a fire rated consumer unit through separate holes can lead to some issues. I encountered this exact issue today for the first time and i am unsure whether this is likely to warrant anything higher than a C3 given that it is a small single phase domestic installation. I have looked through the regs and struggling to see anything very clear on how this matter should be considered.
Thank you in advance for your help
Is this an eddy current issue or something else?
HI, that is the potential issue i am referring to yes. This installation seemed to be suffering no adverse effects and the fact the tails entered through separate holes was something i observed and thought should be recorded on the EICR, but as i say it did not seem to be causing any problems. I believe the c/u has functioned like this for 5 years with no signs of overheating etc.
Reply to Mains tails EICR coding in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
In the 80's I was taught that with PME earthing arrangements we used 16mm for the main earthing conductor, some went a bit crazy and were bonding...
When I was on the electric board We had a pair of pillocks connect a housing estate to a very large genset, the n lead was in two parts and not...
Recommended Sponsor News
thanks for the clarification. ( also thanks to Dan. ).
More info on link below http://sbsc.uk.net/
9K
Happy Friday Everyone! Subscribe for more jokes direct to your mailbox or send us your own jokes to be in with a chance of featuring, by clicking...
6K
