Mains Water Closet direct Flush valves still a rarity in UK? Discussion Thread | on ElectriciansForums
Discuss Mains Water Closet direct Flush valves still a rarity in UK? Discussion Thread in the Plumbers Forums area at ElectriciansForums.net
This is an RSS feed of thread: Mains Water Closet direct Flush valves still a rarity in UK?
Content of the thread: Just was at a caravan site in Lake District recently, which had some very interesting Delabie electronic tap and shower fittings, also direct WC flush valves which worked extremely well.
Always wondered why these valves didn’t seem to catch on in UK when very many other countries never use cisterns.
A quick look in the Delabie specs sheet reveals their valves require a 20mm bore feed capable of around a litre per second.
Any gems of wisdom out there? I have put on a hard hat in anticipation of the expected responses
Mains Water Closet direct Flush valves still a rarity in UK? to read more on the original thread at Plumbing Advice
See also UK Plumbing Advice for all UK plumbing advice needs.
Reply to Mains Water Closet direct Flush valves still a rarity in UK? Discussion Thread in the Plumbers Forums area at ElectriciansForums.net
This is an RSS feed of thread: Testing zone valves electrically..? Content of the thread: Can you test zone valves electrically to find out what...
Ideal Standard Dual Flush Cistern Overflow Problem Any help greatly appreciated. It appears that every time i flush the toilet the cistern fills...
damobolton
