Maintained EM Lights on PIR | on ElectriciansForums
Discuss Maintained EM Lights on PIR in the UK Electrical Forum area at ElectriciansForums.net
mattg4321
South East UK
Got some emergency lighting to fit this week. Spec is vague.
Normally the key switch would be switching only the feed to the EM battery pack - not the whole circuit as I’ve seen some do. However the lights are all controlled by PIR. Does this have any impact? Can imagine they will be hard to test properly if the main room lighting keeps pinging on.
Cheers
Thinking I’m going to switch both the line supplies to the maintained EM light only via a DP key switch. If the other lights in the room keep coming on that shouldn’t be a problem?
Forgot to add these rooms have no windows! So the lights will come on!
Got it sussed eventually when I woke up this morning.
I’m going to switch both lines for the emergency fitting only via a double pole key switch. If I only switch the line to the battery pack you won’t even be able to tell if the emergency light illuminates as the fitting will still be turning on from the PIR
Test facility will put I to test mode you shouldn't need to isolate both poles.
Lucky I ran the extra cables. Breaking the supply to the battery turned on the emergency part of the fitting, but it didn’t go into a test mode and turn off the light.
Had to break both line conductors to fitting in a dp key switch.
Ansell fittings.
Reply to Maintained EM Lights on PIR in the UK Electrical Forum area at ElectriciansForums.net
Fitted a lot of this sort of light recently, with all tests reporting back through central Dali controller(s).
nicebutdim
N
Anywhere where the normal lights are dimmed or dimmable the emergency lighting should be of the maintained type. So maintained emergency lighting...
davesparks
