Maintaining top entry fire rating/IP rating | Page 3 | on ElectriciansForums
Discuss Maintaining top entry fire rating/IP rating in the UK Electrical Forum area at ElectriciansForums.net
London
Evening all
Had a job yesterday, which I'm back at next week. Job was to install new dual tarriff CU. As can see from photo earthing was supplied off a clamp from incoming metallic pipe which contained the supply cables. As this old CU is double packed out with a frame it had ample space to house this pipe. Problem being when fitting new CU this isn't case. So after chat with mr NIC man I opted to drop board by 100mm jigsaw out top entry and use 100mm plastic trunking across top to house these cables and pipe. He seemed bit unsure at first as much as me but checked it out and said that as we have maintained IP4x at top all is fine. I questioned about the fire rating and he said that this is fine to. What are people's thoughts? I'm back there next week so maybe can improve but thoughts are even if use loads of glands on top and trunking on top surely these are only so resistant to spread of fire.
Cheers
[ElectriciansForums.net] Maintaining top entry fire rating/IP rating
Unfortunately it comes down to lack of skills, time, money.
But recognising different cable types, their uses and how to handle them is surely a very basic skill whatever level you are at as it is not all T&E in the domestic setting as the OP has found out
Its a shame the way this industry has become, completely scoped and split into sectors, with that it has its consequences.
It probably takes longer to become a London taxi driver now than it does to get some basic qualifications to masquerade as an electrician
then again, how many of today's sparks would recognise lead sheathed twin cable.at first glance, it looks just like pvc/pvc t/e.
I've got a rewire coming up in a month or so with some of that still currently operational ! It's an old 3 storey cottage,open beams on the ground floor and full of furniture. Can't wait.
@MickSmith5824 if you have an issue with any posts then report them by hitting the report button as opposed to insulting forum members. This thread has somewhat drifted off topic which is not uncommon on here.
Reply to Maintaining top entry fire rating/IP rating in the UK Electrical Forum area at ElectriciansForums.net
Nothing wrong with it. Which manufacturers have you got this information from? What do you mean by trip speed? Fuses and MCBs can operate in the...
davesparks
