W
Wallace-ISL
Does anyone know of a manufactured adpatable box with insulated connections or 4 x bus bars with 10mm studs either end, that I can connect via crimps an old 4 core ( imperial just larger than 70mm conductor) so that I can split down to single phase boards locally.. cannot find the manufacturer of the boxes we used to use to joint large SWAs when doing data centre work and resin jointing would not look quite right and trying to avoid using a £500 200A MEM / Eaton Switch Disconnector.
any assistance would be much appreciated..
cheers
Roger
cheers
Roger
