Making one 12/3 wire into two 15 amp circuits | on ElectriciansForums
Discuss Making one 12/3 wire into two 15 amp circuits in the UK Electrical Forum area at ElectriciansForums.net
Reply to Making one 12/3 wire into two 15 amp circuits in the UK Electrical Forum area at ElectriciansForums.net
It will pull 21.4 amps which is an actual load and the breaker is sized based on the calculated load. Which is 30 amps
Yes you will need to install # 4 wiring times 4 for your 2 hots, 1 neutral and 1 equipment ground. As for keeping the grounds and neutrals...
