ive been having trouble with the signal lately so a week ago i took it apart.
i found the connection from the aerial to the pcb had come off (bad soldering)
i grabbed the nearest bit of cable and soldered it up and its as good as new.
while i was at it i put a 12-5v transformer and switch in there feeding a usb port in the battery compartment.
now when i find the exact size diodes i need across the d- and d+ pins to get the required voltage to charge at 1amp ill be happy.
