Malibu Light Timer photocell function not working | on ElectriciansForums
Discuss Malibu Light Timer photocell function not working in the DIY Electrical Advice area at ElectriciansForums.net
Deleted member 147834
Hi all,
I have a Malibu 120W Light timer for low voltage outdoor lights. When I manually set to ON, the lights go on, so I know the lights are wired correctly. But the timer is set to run off the photocell: lights on at dusk, and off 4 hours after dark. However the lights do not turn on at dusk. I assume the next thing is to replace the photocell, or does anyone have experience with this issue who might have an alternative solution?
Cheers
Codi in California
Reply to Malibu Light Timer photocell function not working in the DIY Electrical Advice area at ElectriciansForums.net
Yet another update: I believe what EDF have done is moved me from an Economy 9 to an Economy 7. I've just emailed them to ask if they can switch...
As above, check the whole cable run and look for damage or any junction boxes that might have trouble inside them. Water getting in is a common...
