Manual motor starter | on ElectriciansForums
Discuss Manual motor starter in the Commercial Electrical Advice area at ElectriciansForums.net
J
jimmer
Been to a job in a poultry unit and there are some moller PKZM manual motor starters connected to 3 phase busbar in a consumer unit, not sen it done like this before. This is in a sub board supplied by a C32 TP mcb. Is this technically to regs? Do these starters cover short circuit as well as over current?
All help much appreciated
I've seen it a few times, some manual motor starters are rated to be installed as MCB and motor protection directly off the busbars.
Reply to Manual motor starter in the Commercial Electrical Advice area at ElectriciansForums.net
Hi All, I have recently purchased a motor soft starter from aliexpress for a 3 phase motor Before connecting load I measured the input and...
Hi, Thanks for that, you learn something new almost every day! Regards Griffey
