Manual switching of mcbs | on ElectriciansForums
Discuss Manual switching of mcbs in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
norfolk
I am in the middle of a series of eicr for a car dealership there's about 9 branches to do
in one of the branches they turn off the lights in the workshops every day with the mcbs as there are no light switches
now for one thing the markings on the mcbs have worn off so I'm unable to verify type and rating, but I can't find a blk n whi reg to say switching mcbs under load daily is wrong
Mcbs are not functional switching, and on the sides of the mcb should be information to the what's n wherefores of breaker ( usually )
Verification of mcbs will have to go down as needing further iinvestigation
bgb says
some breakers suitable for frequent switching and some not , breakers are memsheild 1 20 yrs old so prob not suitable
General purpose MCBs are usually designed to operate infrequently and will have an electrical and a mechanical service life based on the number of operations and this is usually less than for a switch designed for operational switching.
So although there should be no danger with using the MCB you will find that the MCB will fail fairly rapidly, which could then cause a danger.
I seem to remember being told about a company that, for safety, tested their RCDs push buttons every day and found that they had a very high bill for replacement RCDs because they were worn out!
Yes agree with Biff...I remember reading in one of the IET's lovely books that MCB's can be used for functional switching....I still personally do not like it though! Why a separate 'proper' switch could not be fitted adjacent to a CU is beyond me.
60898 , 60947 & 61009 mcbs are acceptable to be used for functional switching ( table 53.2 )
Yep, MCB's can and have been used for functional switching (normally lighting circuits) for as far back as i can remember!! It was quite normal to see commercial premises and workshops, utilising the MCB's for switching lighting...
Reply to Manual switching of mcbs in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
A kettle boiling fish - thats your fault right there... or is it a red herring? :)
The best and easiest way to do it would be turn off the power and take the light switch out and splice the 2 wires on the switch together. Your...
