super
marcist 4inch diamond core cutter new unused in box
model ccu850x
drills through lighlty reinforced,brick,block,engineering brick,concrete brick,natural stone,lintels,kalksandstein,poroton, and concrete pipes
spec
Ø117mm Marcrist CCU850X Diamond Core
165mm length
Coupling Termination ½" BSP
Cuts wet or dry
No segment loss guarantee
Ultimate Performance CCU850X Diamond Core
Marcrist CCU850X Diamond Cores are the fastest universal wet or dry combi core ever. They drill 80% of all building materials dry, even granite, and lightly reinforced concrete. Dynamically balanced, and accurate cutting to within +/- 0.3mm, and offering the lowest cost per cut, as low as £0.09 [ 9 pence ], due to a service life expectation of up to 500 holes per core - Experience the difference !
Test time trials to cut a 127mm hole 200mm deep through 12mm reinforced 45N concrete - 6 mins from unpacking to repacking all tools.
Retail at £135
im selling this one for £80 inc delivery in the uk
model ccu850x
spec
165mm length
Cuts wet or dry
Retail at £135
