Marks above old consumer unit | on ElectriciansForums
Discuss Marks above old consumer unit in the DIY Electrical Advice area at ElectriciansForums.net
Mike07
United Kingdom
Hi all,
We have quite an old consumer unit and noticed some weird grey marks above it (please see picture). We’ve recently painted this area and over the grey marks but they’ve come back through. Does anyone think these marks are related to the consumer unit or just a random persistent stain?
Thanks so much for any advice anyone can offer!
[ElectriciansForums.net] Marks above old consumer unit
TL;DR
Marks above consumer unit
I very much doubt the consumer unit is causing that.
Original cables buried in the plaster above? Looks like an old property.
Honestly I’m not entirely sure. It is an old property yes, built around 1910. We were just concerned some of the wiring might be deteriorating but we’ve had no issues with any of the electrics?
Your's has a couple is issues, the mcb is not compatible and a blank module is required. It doesn't meet current standards but that doesn't imply it is dangerous. Does the RCD trip when you press the button.
Reply to Marks above old consumer unit in the DIY Electrical Advice area at ElectriciansForums.net
Rather than covering the issue, find where the moisture is coming from and address from that end, is the outside ground level above the inside, is...
I think the problem is, there’s no power at the switch…. So they’re looking for where it comes from.
I'm not sure on the environmental implications, a good quality integrated fitting will last many years and be more energy efficient than the GU10...
davesparks
i would split he tails and fit an additional 2/3 way CU to supply the garage/whatever. that way you could feed in SWA, installung RCDs as and if...
5K
