Massive repair washer / gland adaptor? | on ElectriciansForums
Discuss Massive repair washer / gland adaptor? in the Electrical Appliances Forum area at ElectriciansForums.net
Rockingit
Mentor
Supporter
V.Nearly Esteemed
Somerset
I want to put a 16mm compression gland into an oversized round plate, say 100mm dia or smaller, basically to act as a stopper against a loose object it's supporting (this is a custom stage light). 1mm-ish sheet steel would be ideal but before I go diving around the skip bins of sheet metal companies or seeing how blunt my holesaws are, is there anything like this off the shelf that I haven't come across?
You couldn't work with something as small as a conduit box lid?
Unless it needs to be round, I'd be inclined to take a grinder to some trunking lid.
that's not a bad shout, cheers (or a holesaw to some conduit)
Or even just some tray....
Steel discs on fleabay (if you don't mind cutting the hole in the middle)!
eg:
Is 2mm too thick?
Wondered about that when I posted, but only ever seen overlapping lids in PVC.
A metal lid for 32mm and above conduit boxes is larger but I don't think as big as 100mm. I have some here in a box with other 32mm boxes but I can't find where I put it to measure...
Reply to Massive repair washer / gland adaptor? in the Electrical Appliances Forum area at ElectriciansForums.net
